Fresh install error on saving entry
Wessel's avatar
Wessel
5 years ago
Wessel's avatar Wessel
Hi all,
Just launched a new website using GIT, al files are transferred but at the live version I get this error when saving an entry. Local this is working just fine….
Tried to set back PHP to 7.2 instead of 7.4 but gives no solution. You guys any clue?
Kind regards:
Wessel
Lines from the RTE file which is referring to
        if (!empty($pageData)) {
            foreach ($pageData as $page) {
                $tags[] = LD . 'page_' . $page->entry_id . RD;
                $urls[] = $page->uri;
Notice Undefined property: stdClass::$entry_id ee/ExpressionEngine/Addons/rte/RteHelper.php, line 434
Severity: E_NOTICE Notice Undefined property: stdClass::$uri ee/ExpressionEngine/Addons/rte/RteHelper.php, line 435
Severity: E_NOTICE Warning Cannot modify header information - headers already sent by (output started at ee/legacy/core/Exceptions.php:120) ee/legacy/core/Input.php, line 251
Severity: E_WARNING Warning Cannot modify header information - headers already sent by (output started at ee/legacy/core/Exceptions.php:120) ee/legacy/core/Input.php, line 251
Severity: E_WARNING Warning Cannot modify header information - headers already sent by (output started at ee/legacy/core/Exceptions.php:120) ee/legacy/libraries/Functions.php, line 458
Severity: E_WARNING
Rob Allen's avatar
Rob Allen
5 years ago
Rob Allen's avatar Rob Allen
Yes RTE seems to be a bit buggy currently, it’s been reported a few times so hopefully EE will have a fix soon.
In the meantime to bypass the bug you could change RTE fields to Textarea’s so you can start adding entries with the errors. Alternatively use a 3rd part addon like https://eeharbor.com/wygwam or https://addons.reinos.nl/wyvern as they seems to work fine.
Wessel's avatar
Wessel
5 years ago
Hi Rob,
Thanks, unfortunately Wygwam is facing errors to when using in a Grid field. Already created a ticket at EE harbor. Normally i do use wygwam. But because of the error my idea was to use RTE for the time being and update the fields to wygwam when issues are resolved.
Third option then, Wyvern. Thanks for advise!
Rob Allen's avatar
Rob Allen
5 years ago
I did it the other way around, used RTE first (errors) then go to WYGWAM (no errors).
I have WYGWAM 5.1.0 working fine on EE6.0.3 in grids and grids in fluids, PHP7.1.
Wessel's avatar
Wessel
5 years ago
This issue is resolved by the new Assets and Wygwam versions.
? 1
