Custom URLs break pathing??
Skythe's avatar
Skythe
5 years ago
Skythe's avatar Skythe
You got a template at about/index.
If should be accessible via about/my-fancy-url.
You fill out the Template route override field at Template > Access.
The page is now accessible via about/my-fancy-url.
But neither {route="about/index"} nor {route="about"} or {path="about/index"} or {path="about"} return the correct URL!
Am I holding it wrong?
P.S. I tried with a non-index page and got the same results btw.
P.P.S. The Preview button on this forum does nothing?
Skythe's avatar
Skythe
5 years ago
Anyone who’s not a spam bot?
Zignature's avatar
Zignature
5 years ago
Zignature's avatar Zignature
Did you try creating a template route at Developer > Templates > Template Routes?
https://docs.expressionengine.com/latest/control-panel/template-manager.html#template-routes
Skythe's avatar
Skythe
about 5 years ago
Hey Zignature,
as far as I can tell, Developer > Templates > Template Routes does the same as Template > Access > Template route override. A route you create via one tool will appear in the other.
But the problem remains: I’m not able to link to that template via any {path=xxx} or {route=xxx}.
Looking at the (bad) documentation, I cant help but ask what that’s supposed to be. The example is /segment/{variable}/{variable:rule}/{variable:rule0|rule1[arg]}. What? How about you explain the basics first? How do I link to a template using a custom route? Why does the documentation explain the most complicated route (and only that), but not how to link to it? That makes no sense.
Maybe its just not possible (anymore).
Zignature's avatar
Zignature
about 5 years ago
I successfully created a couple of routes after reading this tutorial: Template Routes for Single Entry / Permalink URLs.
By the way, the routes I created through Developer > Templates > Template Routes do not appear at Template > Access > Template route override
Skythe's avatar
Skythe
about 5 years ago
@Zignature Are you running the current EE 6.0.3? My EE does not do what you describe.
I’ll go through the tutorial you posted and report back.
Skythe's avatar
Skythe
about 5 years ago
Alright, I think I got it now. This won’t work with EE, but it’s not a bug either.
I wanted to create long and fancy URLs for pages without having to use those long and fancy URLs in path variables or as names of the template groups.
I wanted the template group to be test, link to it via {path="test"} or {route="test"} and have EE turn the link into whatever I declare in the CMS, like /very-nice-page-with-lots-of-content.
That’s not how custom routes work in EE. They’re not aliases. They’re invisible template groups that include existing template groups when called.
Thanks @Zignature for your time and effort! <3
Zignature's avatar
Zignature
about 5 years ago
You can use the URL Title field for that, unless you want it set dynamically.
And maybe Variable Modifiers would work for your use case: https://docs.expressionengine.com/latest/templates/variable-modifiers.html#url_slug
P.S. I’m running EE 6.0.3 😊
Zignature's avatar
Zignature
about 5 years ago
Actually, variable Modifiers are for output, not for input I guess.
