How do I close an entry?
Caja's avatar
Caja
5 years ago
Caja's avatar Caja
I don’t want to delete the entry, just close it so it’s not visible on the website. How do I do that?
webnology's avatar
webnology
5 years ago
webnology's avatar webnology
Hi Caja, open the entry, and choos ‘Closed’ in the Options tab.
Michel
Caja's avatar
Caja
5 years ago
Caja's avatar Caja
I can’t see an Options tab?
webnology's avatar
webnology
5 years ago
Which version of EE do you use?
Caja's avatar
Caja
5 years ago
Caja's avatar Caja
5.4.1 - we haven’t dared to upgrade to 6 yet.
webnology's avatar
webnology
5 years ago
Anyway, it is the same on all versions. Just open the entry, and at the top, on the right of your ‘Publish’, you see the Options.
Caja's avatar
Caja
5 years ago
Caja's avatar Caja
Nope, all I got there is “Publish, Pages and Hidden”.
webnology's avatar
webnology
5 years ago
Strange, can you give me a screenshot?
5 years ago
I would also take a peek to see if you have a publish layout tied to this channel.. It could be hidden in there.
It’s also worth checking the channel to make sure you have Statuses tied to it.
Caja's avatar
Caja
5 years ago
Caja's avatar Caja
Hi, apparently the person who made the website didn’t add those options to that channel in layout, I fixed that and the whole thing is solved, I could now close that entry. Thank you so much for the help!
