Can't update from 5.4 to 6 using one click update
Bill the Grue's avatar
Bill the Grue
5 years ago
Bill the Grue's avatar Bill the Grue
Hello,
I’m running 5.4 (php 7.4) and I want to upgrade to version 6. When I click the one click updater, I see a message saying I am up to date. Is there something I should change so I can upgrade from 5.4 to 6 using the one click updater?
5 years ago
Hi Bill,
Thats kind of odd.. If it’s still happening, you might have an old file for current_version in your cache folder that needs to be deleted. There after it should force the check again.
Does that do the trick for you?
Thanks, -Tom
Bill the Grue
5 years ago
Thank you for your reply. The file current_version had the error message right there: cURL was missing. I had updated PHP and forgotten to include curl when I updated.
After installing curl, the update worked exactly as intended.
5 years ago
Awesome, glad to hear it!
