Admin is not working
jostar's avatar
jostar
5 years ago
jostar's avatar jostar
Hi all. I manage to update an old site even to v5 . The site is working ok but I can not login to the Admin page. The logins just refreshing and stay there.
Any clue?
jostar's avatar
jostar
5 years ago
ee-wizard says: YAY! Congartulations! Your server is ready toy use EE
5 years ago
Are you still running into an issue? Usually if it’s just refreshing, you’re either losing the post data or you have a cookie issue. See if this helps: https://docs.expressionengine.com/latest/troubleshooting/general.html#submitting-a-form-has-no-effect-and-the-page-simply-reloads
If it’s not a rewrite losing the post, look at your headers- see if it’s trying to set a cookie and can’t.
You might even ftp in and set an override so the cp using a session id and not cookies- see if that gets you in:
https://docs.expressionengine.com/latest/general/system-configuration-overrides.html#cp_session_type
$config['cp_session_type'] = 's';
jostar's avatar
jostar
5 years ago
Thanks Robin, that did the trick. I have just read it and fixed it.
? 1
