I have an install of the latest version of EE on my webspace and have the website set up. It is a 1 page solution.
The only issue I am encountering is with the Contact Module; when I go to submit the form it is downloading the message instead of posting it. The website is working on an SSL subdirectory basis as that is how the hosting provider allows native SSL ability for the website.
When I send a test mail through the backend “Developer > Utilities > Communicate” the test email goes through to the desired receipt however as previously stated on the front end homepage the form does not send, it just downloads.
My code for the EE module is:
{exp:email:contact_form user_recipients="no" recipients="[email protected]" charset="utf-8" form_class="needs-validation" form_id="contact-form" return="https://clarahost.clara.net/www.aftech-engineering.co.uk/" redirect='0'}
<input type="hidden" name="from" size="40" value="Enquiry From Website" />
<input type="hidden" name="to" size="40" value="[email protected]" />
<div class="row">
<div class="col-md-6 mb-4 pb-2">
<label for="Name">Name</label>
<input type="text" class="form-control" id="Name" placeholder="Name" name="name" value="" required>
<div class="invalid-tooltip">
Please enter your name
</div>
<div class="valid-tooltip">
Brilliant - Thanks!
</div>
</div>
<label for="Email">Email</label>
<input type="email" class="form-control" aria-describedby="emailHelp" id="from" name="from" placeholder="Email" value="" required>
Please enter a valid email address
</div>
Brilliant - Thanks!
</div>
</div>
</div>
<div class="row">
<div class="col-md-12 mb-4 pb-2">
<label for="Message">Message</label>
<textarea name="message" class="form-control" id="Message" placeholder="Message" rows="5" required></textarea>
Please enter an appropriate message
</div>
Brilliant - Thanks!
</div>
</div>
</div>
<div class="form-group">
<div class="form-check">
{if captcha}
Please enter the word you see in the image below:
{captcha}<input type="text" name="captcha" value="" maxlength="20" class="ml-0 ml-md-2" /></p>
</div>
</div>
<input class="px-5 py-2 btn float-right btn-block btn-lg text-uppercase" name="submit" type='submit' value='Submit' />
{/exp:email:contact_form}The website is: www.aftech-engineering.co.uk/
The contact form is found at the bottom of the page.
Any help with this would be very much appreciated.
I’d ping the host and ask- I’m not sure I’ve seen that before. I’d personally toss up a copy of the form and just have it post back to itself and see if that works.
Plus www.aftech-engineering.co.uk/ is redirecting.
But this looks like something the host will need to resolve.
Ah- sorry. I’d make a file named test.php and I’d put this on it:
<form id="contact-form" class="needs-validation" method="post" action="" >
<div class='hiddenFields'>
<input type="hidden" name="ACT" value="25" />
<input type="hidden" name="RET" value="https://clarahost.clara.net/www.aftech-engineering.co.uk/" />
<input type="hidden" name="URI" value="index" />
<input type="hidden" name="PRV" value="" />
<input type="hidden" name="recipients" value="uRQwNZEl0sJakkGRZJ1NQ7Ha05DUAt+Pbjx0wTaK+8jXieBf+EtkoowIoj+7UXMkSGytKppBfdHuaGXDYFPMzQ==" />
<input type="hidden" name="user_recipients" value="DuV4zGIHI8vZ60Cg4uKQnbQg3+u7BGVMNSi02zTH45o=" />
<input type="hidden" name="charset" value="utf-8" />
<input type="hidden" name="allow_attachments" value="912SQz8yugKiJvHV3g7XD28hyvTHUUehbQ/KHyCONbeZqSHgdkCo6YSZy3ZkEcvN" />
<input type="hidden" name="redirect" value="0" />
<input type="hidden" name="replyto" value="" />
<input type="hidden" name="markdown" value="sG7h6U7ArScZ3puVk6xN8BhHBpQVYuONyUv5jzMwEjc=" />
<input type="hidden" name="site_id" value="1" />
<input type="hidden" name="csrf_token" value="8727bd427001b94b82f77f11bf95b52ee14013cb" />
</div>
<div class="row">
</div>
Brilliant - Thanks!
</div>
</div>
</div>
Brilliant - Thanks!
</div>
</div>
</div>
<div class="row">
</div>
Brilliant - Thanks!
</div>
</div>
</div>
images/captchas/1600119821.5364.jpg<input type="text" name="captcha" value="" maxlength="20" class="ml-0 ml-md-2" /></p>
</div>
</div>
</form>Submit the form, let’s see if it works. Note- it’s not going to do anything/send emails. It should just reload the page with all the posted data in a big messy lump at the top of the page.
Hi Rob,
Thanks for the help with this.
I created the page as per your instructions and it seems to post and redirect back however the input data is not being shown at the top of the page.
Please see the link to the page here: Form Test
Would you have any advice on why the EE install is not parsing the form correctly however the standalone test page can?
I have even tried the contact templates form and it is not working, when I open the downloaded file I get:
Status: 404 Content-Type: text/html
Virtual host not found on this server
Take a look at your path and url settings- for your base_url set it to https://clarahost.clara.net/www.aftech-engineering.co.uk/ and for your site_url set it to {base_url}.
Right now, it looks like it’s posting to https://clarahost.clara.net. And you can’t get to www.aftech-engineering.co.uk - that’s redirecting to https://clarahost.clara.net/www.aftech-engineering.co.uk/.
Let’s see if that helps. You can change it back once the domain is setup.
Glad that was it! I was missing the bad action url because we were getting such a weird error!
Just make sure to use {base_url} and {base_path} in all of your control panel settings and then when you need to change it to the real url and go live, you’ll only need to edit it in that one spot.
