How do you create filters?
maxi's avatar
maxi
5 years ago
maxi's avatar maxi
Hi there, hope you’re all safe and well.
How have you guys set up your templates to allow user to filter entries?
I built my template 9 years ago using the Low Seg2Cat plugin to have SEO friendly urls, but it doesn’t really allow for multiple filters using tick boxes, radio buttons, sliders etc.
My filters are currently just links such as “../brand/acme” which filters if segment_2 is ‘brand’. It’s not very scalable and would like to refactor page. Ideally the experience you get with the FILTER menu on this page: https://themes.getbootstrap.com/preview/?theme_id=28750
Very curious to see how you guys have so approached it 😊
Thank you
maxi's avatar
maxi
5 years ago
maxi's avatar maxi
I see a few add-ons are available so I was wondering what’s the leanest and most flexible solution as of today.
maxi's avatar
maxi
5 years ago
maxi's avatar maxi
I saw Reefine in the Add-Ons section, is anyone using that? Are there any other solutions to consider? Thanks!
5 years ago
Hrm- a lot of ways to approach it. I have not played with Reefine yet, but I absolutely would before making any decisions. It looks really slick, he’s responsive on Github, and there is no reason not to try it. I have GOT to start playing around with the new add-ons more!
An old faithful option you could look into is Low Search- it’s not just a search form and can definitely be used for filtering.
And then I’ve rolled my own with the search parameter and segment logic- not unlike your Seg2Cat approach.
But I would absolutely kick the tires on Reefine and then go from there.
