Change primary site
News and General
hieu abc's avatar
hieu abc
5 years ago
hieu abc's avatar hieu abc
I am using multiple site manager and the first site I created my license with, I no longer use. I use the MSM other sites. My goal is to delete the primary site and use it to create a new site. How can I get a new license or be able to fix this problem?
5 years ago
Hello,
There are really 2 separate issues. The license count is an easy fix. Since ExpressionEngine went open source with the release of version 5, older downloads are available for free. And if you have MSM installed and need another site added, just drop an email to [email protected] and they’ll help you out.
Second issue- deleting the primary site. That’s less easy. There isn’t a ‘clean’ way to delete the default. I can think of two options- swapping out another site to be the new ‘id 1’ by manually altering all of the site ids. Or possibly hacking it so the delete routine works on id 1. You’d have to be super careful with either option.
Given the choice, I’d leave it and just add another one.
madhusinghGodgrace14@'s avatar
5 years ago
madhusinghGodgrace14@'s avatar madhusinghGodgrace14@
Hello,
I use several web administrators, and I no longer use the first platform I built my license for. I use other MSM pages. My goal is to uninstall and use the primary site to build a new site.
Thanks, https://askmeoffers.com/
5 years ago
If it were me, I’d delete the entries, channels and templates from the primary site and either re-use it or let it sit. It’s not going to hurt anything to do that and you don’t gain anything from simply switching the site id around in site_id 2. And there are just a lot of places for it to go wrong manually switching it.
It’s definitely not worth the work and the risk to try and make a different site the ‘default’- there’s no benefit to it.
