Disable individual sites in MSM
TN_GSO's avatar
TN_GSO
5 years ago
TN_GSO's avatar TN_GSO
When I disable a site in MSM, it appears to disable all the sites. Is there a way of disabling individual sites in MSM, or a config I need to implement in order to make this possible?
5 years ago
If you go to the MSM site dropdown and select ‘Manage sites’, then click the ‘edit’ icon by the site you want to turn on/off, you should get a form where you can set the site’s short name, etc. There’s also a ‘Website online?’ toggle- that should let you take the individual sites offline.
TN_GSO's avatar
TN_GSO
5 years ago
Ahhh OK, I’ve been going to Settings -> and using the Toggle there. I’ll use that route instead and review. Thanks.
