Importing from a WordPress backup
ChrisClark's avatar
ChrisClark
5 years ago
ChrisClark's avatar ChrisClark
I’m coming back to EE after a long absence (was on SquareSpace for years, then spent the last year trying to hand-code everything). I have a WordPress-formatted export from my old SquareSpace blog. Would the DataGrab plugin be my best bet for importing that into an EE channel? Or are there other options I should be looking at?
Thanks in advance for any assistance you can provide.
Brian Litzinger's avatar
Brian Litzinger
5 years ago
Yeah, DataGrab might be your best bet b/c you can customize the import, e.g. what data goes where.
? 2
ChrisClark's avatar
ChrisClark
5 years ago
Thanks, Brian!
