GoDaddy Issue?
rjanuska's avatar
rjanuska
5 years ago
rjanuska's avatar rjanuska
I think I may be having a GoDaddy issue with my paths. I’m moving a site from version 2.2.2 to version 5.3.2. I’m not doing the update, the site only has 30 entries. The current site works on the front end but the back end of version 2.2.2 is a hot mess. I have manually moved the templates from the 2.2.2 version to a fresh 5.3.2 version and am getting the following error “No input file specified” when I try to go anywhere from the homepage (which is working)
When I try to pull up the home page www.domain.com/{template_group}/ I get the same error message, but just domain.com and domain.com/index.php gives me my homepage with the appropriate content.
Any thoughts? The last version of EE I worked with was 2.something but the new version looks familiar enough that I can get around and be dangerous…LOL
Thank you!
  • Rayna
5 years ago
Hi Rayna,
Thanks for getting in touch about this. If you try to access your tempalte_group URL with index.php in the URL does it then work?
So instead of:
It would be:
www.domain.com/index.php/{template_group}/
If so you likely have an .htaccess issue.
rjanuska's avatar
rjanuska
5 years ago
Neither one of those URLs will work and I don’t currently have an .htaccess file because when I did try it it didn’t work either.
  • Rayna
tbritton's avatar
tbritton
5 years ago
tbritton's avatar tbritton
Have you run the ee_wizard on your site to make certain you have all the prerequisites in place? For instance, I had the correct version of PHP, but did not have ZIP checked as one of the modules at GoDaddy (“PHP version” in cPanel under “Software”), so the updater would not work. Sometimes it is stuff like that.
Terry
? 1
rjanuska's avatar
rjanuska
5 years ago
Unfortunately the ee_wizard doesn’t work at all….
  • Rayna
tbritton's avatar
tbritton
5 years ago
Then you are having major issues, and I recommend you call the very helpful tech support folks at GoDaddy.
I used the ee_wizard just the day before yesterday at GoDaddy’s servers while setting up a new project and it worked perfectly.
Terry
