Combo Load - Plugin Low Variables - 3.3.1 Errors
motoracer's avatar
motoracer
about 6 years ago
motoracer's avatar motoracer
Hi, When using the Low Variables plugin, an error appears in the console:
<div class=”err-wrap notice”> <h1>Notice</h1>
A non well formed numeric value encountered
ee/legacy/libraries/Javascript_loader.php, line 148 <ul> <li>Severity: E_NOTICE</li> </ul> </div>
Badly url - admin.php?S=0&D=cp&C=javascript&M=combo_load&plugin=ui.touch.punch&package=low_variables:low_variables&v=3.3.1&v=1548331170
The error appears from this line - https://github.com/ExpressionEngine/ExpressionEngine/blob/5.1.3/system/ee/legacy/libraries/Javascript_loader.php#L148
The error appeared suddenly. Has anyone encountered such a thing?
I’m using version EE 5.1.3 Low Variables - 3.3.1
Rob Allen's avatar
Rob Allen
about 6 years ago
Rob Allen's avatar Rob Allen
Have you upgraded EE or Low variables recently to make this happen?
motoracer's avatar
motoracer
about 6 years ago
I did update Low Variables but before this was also this error.
about 6 years ago
If possible I would recommend making sure both EE and Low Variables are upgraded to the most recent versions, and test again.
motoracer's avatar
motoracer
about 6 years ago
Unfortunately, I receive an error at the end of the update.
When will I remove from url
admin.php?S=0&D=cp&C=javascript&M=combo_load&plugin=ui.touch.punch&package=low_variables:low_variables&v=1548331170
&v=3.3.1 - the php error disappears
about 6 years ago
We dug into this one a bit more in-depth. It looks like both low variables and EE are using the v GET variable. On the EE side we opened a ticket to add additional validation that it is a timestamp (and get it from the server accordingly if it isn’t).
I’ve also reached out to Low and asked him to consider renaming the his GET variable.
motoracer's avatar
motoracer
5 years ago
Problem solved. Errors disappeared after adding the code.
https://github.com/intoeetive/ExpressionEngine/commit/9a3aa941ea9a3238ae9edc0f097f3ff4dd807733
