textarea not displaying text from channel
andrew001's avatar
andrew001
5 years ago
andrew001's avatar andrew001
I’m creating a front-end form for logged in users to edit their entry. Everything is working fine except for the text area. If I render it in the most basic format like this:
<textarea>This is test text</textarea> = works fine <textarea>{teaser_text}</textarea = will not display the text. As soon as I add the brackets, it wont render the text. Looking at the source code also shows no text.
I do have a rich text field right below it, and that is working, although I had to add:
[removed][removed]
to the page to get it to work.
Any idea how to get the textarea to display text from the channel?
andrew001's avatar
andrew001
5 years ago
I added class=”” to the textarea and now it works as intended. Weird.
5 years ago
It sounds like some javascript might have been running astray? But definitely a weird one.
I think adding the class is a solid solution to it, though the whole thing is odd!
