Expression Engine v4.3.8 says it's “up to date!” so no option to upgrade to 5.x
Ace Prod's avatar
Ace Prod
5 years ago
Ace Prod's avatar Ace Prod
The issue in brief is that after upgrading from EE v3.5.17 to EE v4.3.8 and logging in to the admin panel, the option to “upgrade” displays that it is already “up to date!”, even though version 5.x is available. How can I tell EE that it is not up to date so I can start the one click upgrade process as described here https://docs.expressionengine.com/latest/installation/updating.html?
I have also tried updating via the command line as described, but this also gives me the same issue saying that there is no need to upgrade.
Thanks in advance for any advice given
vw000's avatar
vw000
5 years ago
vw000's avatar vw000
I think that is normal between major versions. If you are on 3, it will only show the latest update until 3. I guess the same is true for version 4. It will only notify about updates on version 4. Makes sense, since major versions tend to change many things that can break projects.
