Is there a way to overwrite Control Panel css?
templateee's avatar
templateee
templateee's avatar templateee
I’ve made some tweaks to the control panel css, but I’ve had to do it in the ‘core’ file: themes/ee/cp/css/common.min.css
I’ve tried to duplicate under: themes/user/cp/css/common.min.css
but no luck, any pointers?
I’d like to be able to do this without creating a plugin if possible
thanks
aquicksharp's avatar
aquicksharp
aquicksharp's avatar aquicksharp
You could try this diginut control panel css-js I think it works on EE5. The control panel is getting completely changed in EE6 so Im not sure if its worth messing around in the css but maybe you are not going to upgrade .
templateee's avatar
templateee
nice! thanks for the link, looks promising,
also EE6?!
