how do I get rid of index.php in link to the forums?
macgeek's avatar
macgeek
macgeek's avatar macgeek
MYSITE/cms/index.php/forums/
  1. is the current link… is their a way to have it go to MYSITE.com/cms/forum
  2. Also how do I get a link to the forum URL from the main page? not sure how to make that happen.
any ideas? thanks.
templateee's avatar
templateee
templateee's avatar templateee
Have you used the .htaccess to remove index.php from the url?
https://docs.expressionengine.com/latest/installation/best-practices.html#removing-indexphp-from-your-urls
(not sure if it’s the same for forums, though)
for a link once you have your forum URL, you could add:
<a href="http://{path=forum}">Forums</a>
where you want the link to display
https://docs.expressionengine.com/latest/templates/globals/path.html#path-variables
(edit: for some reason ‘http://’ is being added to my code snippet, but don’t put that in if you use {path=""} )
(editedit: ok, there is an issue when adding expressionengine code with markdown, the example link will need some tweaking to actually work - link provided to examples)
