Cannot connect to Redis
bbgadmin's avatar
bbgadmin
bbgadmin's avatar bbgadmin
I’m having an issue where I’ve installed Redis and started the Redis server, but EE complains “Cannot connect to Redis, using File driver instead.”
When I’m ssh-ed into the server I’m able to get and set items in Redis using the command line, so Redis is definitely functioning and is accessible on localhost with the standard port.
How would I go about troubleshooting this error? I don’t see any connection errors logged to the developer log.
Gfive(tm)'s avatar
Gfive(tm)
Gfive(tm)'s avatar Gfive(tm)
  • Did you install redis-php module?
  • Does redis use a password?
/system/user/config/config.php
$config['redis'] = array( 'host' => '127.0.0.1', 'password' => 'password if any', 'port' => 6379, 'timeout' => 0 );
macgeek1's avatar
macgeek1
macgeek1's avatar macgeek1
test
