Channel form error in EE5
Tim Print's avatar
Tim Print
Tim Print's avatar Tim Print
I have just updated an old site from EE2 via 3 and 4 to EE5. It seems to be mostly working apart from the exp:channel:form tag.
I have reduced everything to bare minimum for troubleshooting purposes.
I have set up a new channel with no custom fields.
And created a very basic template:
<!DOCTYPE html>
<html lang="en">
<head>
  <meta charset="utf-8">
  <title>Form test</title>
  [removed][removed]
</head>
<body>
  {exp:channel:form
    channel="channel_form_test"
    datepicker="no"
    include_jquery="no"
    return="form-test/thanks"
    unique_url_title="yes"
   <input name="title" type="text">
   <input type="submit" value="Submit">
  {/exp:channel:form}
</body>
</html>
Entries are being generated correctly on form submission but the page doesn’t redirect to the return url and I get the following error.
Warning
call_user_func_array() expects parameter 1 to be a valid callback, class 'EE' does not have a method 'load'
ee/EllisLab/ExpressionEngine/Legacy/Facade.php, line 78
Severity: E_WARNING
Exception Caught
No such property: 'logger' on EllisLab\ExpressionEngine\Legacy\Facade
Facade.php:120
Anyone seen this before or know what is causing it?
Astronacci's avatar
Astronacci
Astronacci's avatar Astronacci
I have the same problem whether you have found the answer…????
LeonKent's avatar
LeonKent
5 years ago
LeonKent's avatar LeonKent
I was listening to one course today, where I heard about the service which may help you. The webmaster told that he uses it to check google archive website to view cached web pages, but also this service can provide to you the site`s audit. You can also see mistakes into your code, so the service will advise you the way to fix it. Check, maybe it will boost your work.
? 1
coxdenis32's avatar
coxdenis32
5 years ago
coxdenis32's avatar coxdenis32
I am very glad that you recommended this resource upgrowth . I recently read a blog about the ability to close large files in databases. These guys know how to curse me. I am confident that my business has received a sufficient amount of trust
Andrei_j's avatar
Andrei_j
5 years ago
Andrei_j's avatar Andrei_j
I read all the comments, but I also have something to add. I think that on this site you will find the answer to your request and a lot of other information. I advise you to follow the link https://hire.careerbliss.com/company/belvg-2/
oplikotre's avatar
oplikotre
oplikotre's avatar oplikotre
useful for me
Sarah Crawford's avatar
Sarah Crawford
about 2 years ago
Sarah Crawford's avatar Sarah Crawford
try looking up the answer on this site. I think you’ll like it
