Working LDAP Login for EE 5?
jhorning's avatar
jhorning
jhorning's avatar jhorning
Hi, we currently have our site on EE2 and are starting the re-build of a completely new version for EE5. We use this add-on to connect to our LDAP server and need the same functionality in EE5. Does anyone know how to get it working or of another add-on that would work for LDAP?
https://github.com/designbyfront/LDAP-Authentication-for-ExpressionEngine
I’ve attached a screenshot of the settings that display on the back-end.
Thanks in advance for any help or info you can provide!
John Fuller's avatar
John Fuller
John Fuller's avatar John Fuller
The add-on needs to be updated to work with the latest version of EE. There are some minor “boilerplate” changes and then likely some minor code changes as well. If you like, I can take a look at it for you. I don’t know if there’s anything else available.
aquicksharp's avatar
aquicksharp
aquicksharp's avatar aquicksharp
Hi John I would be interested in that too Thanks
? 2
John Fuller
Okay, sure. Easiest might be to contact me via email.
[email protected]
? 1
