EE1.5 and EE2.5 to EE5 or PHP7.2 fix
tangotiger's avatar
tangotiger
about 6 years ago
tangotiger's avatar tangotiger
I have two sites, both running on PHP5.6. I just learned I need to get to PHP7.2, and when I did that, the sites stopped functioning. If there is a fix for that, I’d love to see it.
If there is no fix, then I guess I need to be in EE5. - The EE1 site is in “archive” mode. So, ideally, I don’t have to go EE1->EE2->EE3->EE5 just to get it into a breathable state. I’d love to hear from the folks here. - The EE2 site is active. It seems as EE2->EE3->EE5 is my only shot here? If so, I’ll bite the bullet.
Finally, if I migrate my EE2 active site, can I leverage that for my EE1 archive site? So, just have one installation?
Thanks to any insights!
tangotiger's avatar
tangotiger
about 6 years ago
I tried upgrading from EE1 to EE2
https://docs.expressionengine.com/v2/installation/upgrade_from_1.x.html
When I got to the upgrade wizard, and clicked through, I got to a page not found. I repeated all the steps one more time, to no avail. I turned on debug, and below is the message. Where exactly is PATH_CORE set?
A PHP Error was encountered Severity: Notice
Message: Use of undefined constant PATH_CORE - assumed ‘PATH_CORE’
Filename: updates/ud_1_05_02.php
Line Number: 42
tangotiger's avatar
tangotiger
about 6 years ago
Ok, so I think it’s related to my being unable to access the Admin tab pre-upgrade.
That is, at some point, probably when there was a PHP upgrade on my host, I lost usage to the Admin tab. So I think if we can figure that out, then I can proceed.
