{status_menu} dont works [solved]
Andrés Molina's avatar
Andrés Molina
Andrés Molina's avatar Andrés Molina
Im have this
{status_menu} Status
<select name="status">
  {select_options}
</select>
{/status_menu}
inside
{exp:channel:entries channel="mychannel" require_entry="yes" status="draft|reviewed|published|closed|Procesando|Aceptado|Entregado|open"}
                    {status_menu}
Status
  {select_options}
</select>
{/status_menu}
But template parser show me {status_menu} in the html result
My error, in {exp:channel:form channel="news"} <input name=”title” type=”text”> <input type=”submit” value=”Submit”> {/exp:channel:form} works fine
