Fatal error: require_once():
andrew001's avatar
andrew001
andrew001's avatar andrew001
So, I made the mistake of upgrading from 4.xx to the latest (5.xx) and did not update addons nor disable/remove them/
The site started development 2 yrs ago, and now I have been requested to bring it back to life. Unfortunately, I do not have the budget to update the addons, as they are well over a year old. Most were purchased from eeharbor “mega pack” - which is no longer avalable. (The plugins are, but no budget right now)
I’ve went into the DB and disabled a lot of them in the exp_extensions table, however, I believe that there are still fields still lingering. I found the exp_fields table and mucked about there making a few changes, but to no avail.
Is there any way around this error:
Fatal error: require_once(): Failed opening required ‘/var/www/vhosts/.com/.com/system/user/addons/playa/helpers/eeharbor_ee5_helper.php’ (include_path=’phar:///var/www/vhosts//.com/system/user/addons/assets/assets.phar:.:/opt/plesk/php/7.0/share/pear’) in /var/www/vhosts/.com/.com/system/user/addons/playa/eeharbor.php on line 40
edit : removed domain name.
I fear that once THIS instance is fixed, I will encounter a few others along the way.
I even edited the config file to disable addons.
Is there any way to bypass this to get the site up and running?
Thanks in advance
andrew001's avatar
andrew001
Fixed.
Ended up commenting out various lines of code across 3 files. Then was able to successfully uninstall the addon.
Neil Evans's avatar
Neil Evans
Neil Evans's avatar Neil Evans
Sounds good. The playa extension above could be replaced by the default EE relationship field.
