Format AM/PM abbreviations with periods (AP Style)
Jeremy's avatar
Jeremy
Jeremy's avatar Jeremy
Looking to format am/pm abbreviations with periods “a.m.” and p.m.”. Is this possible without manually formatting this field in entries?
Time: {event_start_date format="%g:%i %a"} – {event_end_date format="%g:%i %a"}
I’d probably lean toward manually formatting it. But- a/A are among the date format variables that are processed through the language variables. In other words- you could make a separate language pack for it. The bit you’re interested in is in core_lang.php.
You could copy over that file, just keep the am/pm and edit it.
But that really seems overkill- I’d just format it manually.
Jeremy's avatar
Jeremy
A challenge with manual formatting is I would be unable to use the localized date field type. I would really prefer to have a way to format with the periods. Any other options beyond overwriting the core_lang.php file?
Well, you wouldn’t overwrite it, you’d make a new language pack with just the one file.
BUT- when I say manually, I meant:
{event_start_date format="%g:%i"} {if  '{event_start_date format="%a"}' == 'am'}a.m.{if:else}p.m.{/if}
Make sense?
? 1
Jeremy's avatar
Jeremy
Thanks, Robin this will work great!
? 1
