Workflow in 2019?
freaksarise's avatar
freaksarise
freaksarise's avatar freaksarise
Hi, I worked in EE for several years until a couple of years ago. We used to use “Better Workflow” by Electric Putty and I was wondering what you guys are using these days for any kind of workflow related functionalities? I’m putting together a proposal to shift my client over to EE and this will help since the workflow component is so important to them. Thanks! PS. I love and miss EE immensely
UPDATE: I did find this add-on: https://expressionengine.com/add-ons/publisher
To clarify what I fully mean by workflow: They are currently using sharepoint with things like Nintex where they define dozens of steps for check-in points with events connected to each point that automate various functions upon reaching these steps. Typically their workflows are massive. I would develop this from scratch in EE but wanted to see if there was something everyone was using in case it saved time. Thanks again.
Welcome back! For the level of workflow you’re looking for, Publisher Lite should be able to handle it. Which you’d already figured out, but I didn’t want to leave you with no reply 😉
freaksarise
Awww. I really appreciate that. Thank you!
? 1
kathy's avatar
kathy
kathy's avatar kathy
In the context of workflow-related functionalities in EE, Garten Of Banban 4 the “Better Workflow” add-on you mentioned used to be a popular choice.
otis's avatar
otis
otis's avatar otis
When considering such complex workflow requirements, pizza tower it’s a good idea to work closely with experienced ExpressionEngine developers or development agencies.
