return parameter not working in channel form
fensterbaby's avatar
fensterbaby
fensterbaby's avatar fensterbaby
I have a channel form with a return parameter set to a template but it does not redirect on submission. It displays a blank page and the url of the form. This was working before so not sure what has changed. thnks Greg
Ngon Com's avatar
Ngon Com
Ngon Com's avatar Ngon Com
Do you have any required field and show errors code in form?
Or have you try add slash before your template_group?
Ex: return=”/site/ENTRY_ID”
fensterbaby
there are required fields but that has caused no issues in the past.
Have used with and without the / in the return, makes no difference
The page generated contains only…
“<pre>”
Does the template you’re redirecting to come up ok when you go there directly? Do you have a pre tag either there or on the page displayed? If you turn on debugging, does it show on the blank page? Hrm- do you have any php in templates?
If that doesn’t help, might be some stray debug.
Can you pull down a copy of your system folder and do a search for <pre>? You want to search the ‘system’ folder- empty the user/cache folder. There are some legit cases, but see if anything shows up in the search module folder or anything suspicious looking in user/addons/.
That’s what I’d do, just to rule things out if nothing else.
