Multi-language
Jason Stringer's avatar
Jason Stringer
Jason Stringer's avatar Jason Stringer
Hopefully I can get pointed into the right direction. I am trying to figure out if ee comes with a multi-language add-on? because I am building a news site that need to translate the site.
Thank you for your help.
There are a couple of ways you can approach a multi-lingual site, but for complex sites, you’ll probably want an add-on.
If that’s the case, then check out Publisher.
Jason Stringer
Robin,
Can you please share where I can get an add-on for ee.
Thank you
Ah- ‘Publisher’ up above is a link- it should take you to the store: https://expressionengine.com/add-ons/publisher
