SQLSTATE[HY000] [1045] Access denied for user 'root'@'localhost' (using password: YES)
News and General
Chad Crowell's avatar
Chad Crowell
7 years ago
Chad Crowell's avatar Chad Crowell
I don’t know where these database parameters are coming from….
I have a EE5 site that I just upgraded from EE2 that works great locally. I’ve deployed the files and db to the development server, and am getting this error: https://d.pr/i/ArJAIp
When I open ee/legacy/database/drivers/mysqli/mysqli_connection.php at line 81, I can see this is an open function for the db connection. If I run die($username) or die($password) on line 76, just above the $this->connection = @new PDO definition, they die with the correct username and password from my database config file. If I hard code the username and password into the $this->connection = @new PDO definition, everything works. However, the connection is erring with root/root as shown in line #0 of the stack trace above. I can see also in that line, that the dbname variable is being recognized, as my db name does start with “au”. This is very confusing… why would it be trying to connect with root/root when the username/password are correctly defined in variables when die()’d in the line above this error?
Chad Crowell
7 years ago
Ugh, ignore me. My main db config file was correct, but I have an add-on that connects to an external db and I had some domain references wrong there. Fixed.
Derek Jones's avatar
Derek Jones
7 years ago
Hey Chad, glad you found it, and welcome back to the forums!
