How do I upload SVGs?
dgtlmkt's avatar
dgtlmkt
about 7 years ago
dgtlmkt's avatar dgtlmkt
I’ve already disabled XSS filtering in the control panel and added the xss_clean_member_group_exception flag for my Super Admin group in my system/user/config/config file. I’ve logged in and out of the system.
What can I do to get the EE File Manager to allow SVGs to be uploaded?
Kevin Cupp's avatar
Kevin Cupp
about 7 years ago
You might also need to set the upload directory to allow all files. On some servers, the file’s mime type isn’t reported as an image.
dgtlmkt's avatar
dgtlmkt
about 7 years ago
Thanks for that Kevin. I did set the upload directory to accept all files, but it didn’t change the situation. I ended up rethinking my asset strategy - since the SVGs are exclusively used by the templates, I just added them as part of the template files instead of manageable files. I appreciate the help.
