Add-on description field in the store parses EE code
Developer Preview
Brian Litzinger's avatar
Brian Litzinger
7 years ago
My URL Helper extension has a {current_url} variable, which appears to be parsing. You can see “https://expressionengine.com/add-ons/url-helper” just after the {page_number} var in the docs. I haven’t tried it yet, but I wonder if it means {exp:channel:entries} tags could be rendered? Could be a security issue.
Derek Jones's avatar
Derek Jones
7 years ago
Globals are parsed in entries if they are in the clear, which enables things like path variables. If you put it in backticks or code blocks, it should display as code properly.
Brian Litzinger
7 years ago
I added back ticks and it’s still parsing :(
Derek Jones
7 years ago
Looks like a bug in the Markdown parser, on it.
Derek Jones
7 years ago
Should be fixed including another bug I found while I was there. Thanks!
Brian Litzinger
7 years ago
The change you made might have broken HTML https://expressionengine.com/add-ons/freeform
Derek Jones
7 years ago
Ah, unrelated. I changed to Safe HTML so people couldn’t enter any old markup. I’ve restored it to All HTML and will work with Kelsey next week on an alternative.
