Markdown table headings forced to align left
Developer Preview
kmartens's avatar
kmartens
7 years ago
kmartens's avatar kmartens
I’m using a feature comparison chart to show the differences between each edition of Freeform, and I have specified :---: etc to align some content centered. I can see that a class of center is being applied to table headings and body rows, but the heading rows remain left-aligned, apparently due to some CSS in default.min.css that’s overriding it. Any chance this can be adjusted? :D
https://expressionengine.com/add-ons/freeform
Obviously not end-of-the-world, but looks a little ugly.
James Mathias's avatar
James Mathias
7 years ago
James Mathias's avatar James Mathias
Place a class of compare on the table itself, and a class of txt-center on the ths you want to have centered text.
You can also put a class of yes on a td with an empty span in the td to get a checkmark, and a class of no with an empty span in the td to get a x.
kmartens's avatar
kmartens
7 years ago
Thanks… I am using markdown for the formatting of the table though, so I can’t actually apply any classes… or are you suggesting I switch the whole thing to HTML?
James Mathias
7 years ago
If you’d like to have a comparison table in your listing you’ll need to use HTML with classes I suggested above, or be ok with the styles as applied to an un-classed table.
kmartens's avatar
kmartens
7 years ago
Derek Jones's avatar
Derek Jones
7 years ago
For reference, Markdown Extra allows for some attributes on some elements, but Markdown-based tables is not one of them.
https://michelf.ca/projects/php-markdown/extra/#spe-attr
kmartens's avatar
kmartens
7 years ago
Interesting, thanks!
