fluid conditional problem
stefanos's avatar
stefanos
7 years ago
stefanos's avatar stefanos
I don’t understand what is the problem using conditional inside fluid tags.
{explain_sub_fluid:count} display the right fluid count: 1,2.. but the conditional {if {explain_sub_fluid:count == 1} } test {/if}, doesn’t works.
I tried too:
           {if explain_sub_fluid:count == 1 } test {/if}
         {if {explain_sub_fluid:count} == 1} test{/if}
No results.
those line commands:
           {if {explain_sub_fluid:count} == 0} test {/if}
display: test…………. but count == 1, count == 2. There are not igual to zero……
Why {explain_sub_fluid:count} works well but the related conditional ( {if {explain_sub_fluid:count == 1} } ) is not processed ? {if {explain_sub_fluid:count} == 0} test {/if} is processed ??
stefanos's avatar
stefanos
7 years ago
This fluid tags embedded in Stash template code give me this problem, working fine in a legitimate EE template .
stefanos's avatar
stefanos
7 years ago
Resolved with: parse_conditionals=”no”
{stash:embed name="explain:main3" process="start" parse_conditionals="no"}
