Ability to export Field Group Sets, without a channel
Feature Requests
FirthCreative's avatar
FirthCreative
7 years ago
FirthCreative's avatar FirthCreative
I’m sure I’m not the only person who has come across this one, maybe someone can suggest a workaround, but failing that the ability to export field groups like we can channel sets would be helpful.
I usually create an SEO field group with a bunch of OG fields etc. This group can be, and is, used by a number of channels. When exporting a channel set that uses this group, the fields are obvisously included within that set, and any others that use it. When importing the channel sets that use the fields in this group it causes errors due to the fields existing after the first set has created them.
Does that read well, I don’t know!? Hopefully you get the idea?
Has anyone else experienced this issue already and found a way to make it work?
