Thanks, for your reply.
Yes that folder was moved.
Just now searched for 4.3.6 to see where it was getting the info and there was a setting in the config file for the version. I manually changed it to 5.0.0 and now EE is showing 5.0 at the bottom and no error message. Is there any other way to confirm I’ve got the right version?
Ah, we may have broken the manual updater. As long as you have the new files in place, you should be mostly good to go, you just need to add these files to your config.php which the updater would have done for you, had it worked:
$config['show_ee_news'] = 'y';
$config['share_analytics'] = 'y';Sorry about that, the one-click updater should be working fine, however. We’ll get a fix for this in the next release.
Thanks for your help, Kevin. Getting there.
When those two lines are added to the config, the admin homepage news box shows 2 errors: 1) the following HTML is exposed in a blue box
" rel="external">RSS[/code/
2) Notice
Undefined variable: url_rss
ee/EllisLab/ExpressionEngine/View/homepage.php, line 174
Severity: E_NOTICE
Line 174 looks like this:
[code]<h1><?=lang('eecms_news')?> <a href="http://<?=$url_rss?>%22class=%22btn" rel="external" class="btn action">RSS</a></h1>Rick
Ricknew, is your install not connected to the internet? You didn’t one-click update, and now it seems it cannot connect to news feed to download the news, so it’s not defining the variable in the controller. Either way, we’ll try to put a fix in to better handle this edge case.
