Create Directory
zack66's avatar
zack66
7 years ago
zack66's avatar zack66
Hi everybody, I hope that sombody will help me, I need to create folder for each page content and template, but when I go to create new folder to upload, the result is not good, EE it show that every thing is ok but it didn’t any new folder where I decided to to it. More, offten happen see point 1)
this is the (Triple) problem:
1) if I create new directory named “test” in “{base_url}images/uploads/” in frontend everything look good, with a new dir in ee dir window, but fisically in the “{base_url}images/uploads/” the new dir is not created. Why???!!
2) if I create new directory named “test2” in “{base_url}images/uploads/test/” in frontend I get in this case error showed in the image 2. Why
3) if I upload some file, in the image 1 is the error that I get. Why??!!
folder permission everything ok :(
Thank you for help….
Derek Jones's avatar
Derek Jones
7 years ago
The folder has to exist on disk before you can add it as an upload location in ExpressionEngine. And then the folder needs to be writeable by PHP. Hope that helps!
