Template routes with categories & pagination
The Design Core's avatar
The Design Core
7 years ago
The Design Core's avatar The Design Core
I’m having trouble getting my template routes to work with pagination & categories.
I have a basic blog which I’ve set up a route to remove the detail page name from the URL, so instead of http://www.mywebsite.com/blog/detail/entry-title-here, I have http://www.mywebsite.com/blog/entry-title-here.
I am using the following template route: /blog/{post:alpha_dash}
This works fine and categories also work fine. But when introducing pagination to the mix, I can’t seem to get pagination to work. Pagination URLs display nothing on the page.
I have segments required set to No. Running EE v 4.2.1.
What do I need to do to get pagination working?
Thanks for any help.
James Mathias's avatar
James Mathias
7 years ago
James Mathias's avatar James Mathias
Here is how we remove the “detail” template from the URL in ExpressionEngine, with the template set up you describe.
/blog/{url_title:regex[(((?!(P\d+|category\/)).)+?)]}
You’ll want to replace category with the actual category separator word you have defined in your CP.
The Design Core
7 years ago
Thank you so much! Works like a charm!
