Admin Field group Divider.
andrew001's avatar
andrew001
8 years ago
andrew001's avatar andrew001
Is there a method, or addon, where I can add a “divider” .. or an HR to separate sections in the channel fields page of the admin?
I have a channel, with many fields in it. I am using a switch to turn sections of content on or off, and each section as several fields. It is way too confusing for the marketing team to figure out. However, if I could insert an HR or something like that, it would help them to visually see the layout options.
Think of a simple landing page that has a Top Banner, Section One, and Section Two. Each one of those as two options.
Section One, Option 1 Section One Option 2
I am using a toggle to allow a user to choose either opt 1 or opt 2. They are basically different layouts.
Depending on the option, there are specific fields. Option one contains a field for H2, a grid (thumbnail, subtitle, copy), whereas option 2 has fields to embed a video, picture and some text.
At the end of the day, this page is very confusing for someone to fill out.
Ideas?
andrew001's avatar
andrew001
8 years ago
I am having OK success by creating a custom layout on collapsing everything that is “option b” - I had to go back to each field and add “default” or “option” next to each name to help clarify things.
I wonder if I could develop a custom field type that just renders an HR or a thick border.
andrew001's avatar
andrew001
8 years ago
Welp, found one if anyone stumbles across this post. Works nice.
https://devot-ee.com/add-ons/publish-notes
