Are UTF8MB4 tables required for EE4?
David Hyland's avatar
David Hyland
8 years ago
David Hyland's avatar David Hyland
I see that EE4 creates UTF8MB4 tables but is this required? My staging server with Nexcess is still running PHP 5.6 and they say that only PHP7 supports UFT8MB4.
I could possibly upgrade the server to use PHP7 but I’ve got several old EE2 sites running there. Does EE 2.8.1 run off PHP7 without issues?
Derek Jones's avatar
Derek Jones
8 years ago
v2.8.1 was released well before PHP 7, so no, it won’t work, but you should be able to easily update to the latest v2. PHP 7 compatibility was added in 2.11.0. You’ll have improved performance and it would be a shame to hobble v4 just because it shares a server with four-year-old software. So that’s my recommendation. But no, v4 doesn’t require utf8mb4 but you will not have any emoji support and will have to do a massive conversion of your database at a later date when you inevitably upgrade your environment.
