E-commerce Omnipay gateway
nermin's avatar
nermin
8 years ago
nermin's avatar nermin
I am using Expresso Store https://www.exp-resso.com for setting up an ecommerce-site. The problem that I run into, is when I try to install a custom gateway. The Expresso Store support claim that my error have something to do with the EE setting and for that reason they can’t help me. I have been trying to find a solution for the last couple of months without luck. So I hope that someone can guide me in the right direction.
To install a custom gateway via expresso store, there are two things that need to be done:
  1. Installing and activating “Store Check” Store Check in order to use Omnipay based gateways.
  2. Installing desired Omnipay gateways provider from: Omnipay Library (Quickpay in my case)
  • I am successful in installing and activating Store Check plugin.
  • I am also partly successful in installing Omnipay-Quickpay
But, when I in the back-end try to activate the newly created “Quickpay gateway” by entering “Settings > Payment Methods > Quickpay” I run into a number of errors. I have attached a couple of screen shots as illustration of this.
  • Store Check setup - IMG
  • Backend setup - IMG
  • Error I get:
Exception Caught
Missing setting options in default setting array
user/addons/store/src/helpers.php:209
Stack Trace: hide details
#0 user/addons/store/views/settings/payment_edit.php(32): store_setting_input('payment_methods', Array, false)
#1 ee/EllisLab/ExpressionEngine/Legacy/Facade.php(132): include('...')
#2 ee/legacy/core/Loader.php(867): EllisLab\ExpressionEngine\Legacy\Facade->runFileInFacadeScope('...', Array, false)
#3 ee/legacy/core/Loader.php(460): EE_Loader->_ci_load(Array)
#4 user/addons/store/src/Cp/SettingsController.php(42): EE_Loader->view('settings/paymen...', Array, true)
#5 user/addons/store/src/Cp/SettingsController.php(498): Store\Cp\SettingsController->render('settings/paymen...', Array, 'payment', 'Quickpay')
#6 user/addons/store/src/Cp.php(69): Store\Cp\SettingsController->payment_edit()
#7 user/addons/store/src/Cp.php(55): Store\Cp->route(Object(Store\Cp\SettingsController), 'payment_edit')
#8 [internal function]: Store\Cp->index()
#9 ee/EllisLab/ExpressionEngine/Controller/Addons/Addons.php(1660): call_user_func_array(Array, Array)
#10 ee/EllisLab/ExpressionEngine/Controller/Addons/Addons.php(920): EllisLab\ExpressionEngine\Controller\Addons\Addons->getModuleSettings('store', 'index', Array)
#11 [internal function]: EllisLab\ExpressionEngine\Controller\Addons\Addons->settings('store')
#12 ee/EllisLab/ExpressionEngine/Core/Core.php(189): call_user_func_array(Array, Array)
#13 ee/EllisLab/ExpressionEngine/Core/Core.php(94): EllisLab\ExpressionEngine\Core\Core->runController(Array)
#14 ee/EllisLab/ExpressionEngine/Boot/boot.php(151): EllisLab\ExpressionEngine\Core\Core->run(Object(EllisLab\ExpressionEngine\Core\Request))
#15 admin.php(143): require_once('...')
Any help will be truly appreciated, as I have run out of ideas where to look for the answer.
Thanks in advance Best Nermin
Derek Jones's avatar
Derek Jones
8 years ago
Hey Nermin, have you contacted the developer of that add-on for support? It’s not likely that their team browses our forums looking for folks needing their help.
