Fluid Field Issue?
Developer Preview
TJ Draper's avatar
TJ Draper
8 years ago
TJ Draper's avatar TJ Draper
I have a strange issue going on where if my custom field is added to a fluid field, fluid field stops setting the input names correctly for fields added to fluid thereafter. It’s hard to explain, I have a video of the issue in action.
https://vimeo.com/252576380
Thoughts?
Seth Barber's avatar
Seth Barber
8 years ago
Seth Barber's avatar Seth Barber
Can you compare the input names in the hidden .fluid-field-templates div with and without your field present in the Fluid field?
TJ Draper's avatar
TJ Draper
8 years ago
The input names are missing the field ID bit in the .fluid-field-templates div when my fieldtype is present.
Before: before
After: after
TJ Draper's avatar
TJ Draper
8 years ago
I can get you access to the add-on if that would be helpful.
