Uninstalling module fires FT `settings_modify_column`
Developer Preview
Jace Richardson's avatar
Jace Richardson
8 years ago
Jace Richardson's avatar Jace Richardson
When uninstalling an add-on, the EE uninstaller fires the uninstall() method in the add-on’s UPD file first and then uninstalls the add-on’s fieldtype which fires the settings_modify_column method.
The settings_modify_column method has code that if the $data['ee_action'] == 'delete', it removes data from the add-on’s custom tables but because the add-on has already been uninstalled, the custom tables no longer exist and the uninstall dies out with a “Base table or view not found” error.
I’ve temporarily rectified this by wrapping the delete code in the settings_modify_column with a conditional to check if our custom table exists but in order to do this, I also have to wipe out the DB cache of table names because it hasn’t been updated since the module was uninstalled:
else if ($data['ee_action'] == 'delete')
    // Clear the DB table name cache.
    if(isset(ee()->db->data_cache['table_names'])) unset(ee()->db->data_cache['table_names']);
    if(ee()->db->table_exists('assets_selections')) {
        // delete any asset associations created by this field
        ee()->db->where('field_id', $data['field_id'])
            ->delete('assets_selections');
So that means that every time the settings_modify_column is called with a delete action, I’m wiping out the EE DB table cache and checking if my table exists (which feels sloppy).
Here is a screenshot of the stacktrace
