Fluid Field: Clicking on the collapse/expand icon collapses entire field
Developer Preview
TJ Draper's avatar
TJ Draper
8 years ago
TJ Draper's avatar TJ Draper
As the title indicates, if you click to collapse or expand a fluid field cell, the entire field is collapsed.
James Mathias's avatar
James Mathias
8 years ago
James Mathias's avatar James Mathias
The main collapse should collapse the entire thing. Each fluid field also has it’s own collapse arrow.
TJ Draper's avatar
TJ Draper
8 years ago
Right, and if you click the fluid field collapse arrow, it collapses the entire field.
James Mathias
8 years ago
Maybe I am misunderstanding you, but it is working as intended in dp2.
TJ Draper's avatar
TJ Draper
8 years ago
https://vimeo.com/240239578/1a00bf2749
James Mathias
8 years ago
Yeah that is not correct, but I can’t replicate on the latest build. Do you have something installed that might be colliding with that JS?
James Mathias
8 years ago
Here is what I’m seeing https://vimeo.com/240240562
Derek Jones's avatar
Derek Jones
8 years ago
I also can’t replicate on dp.3. Anything showing up in your console?
