Issues I've found with EE4 DP1 so far
Developer Preview
Pedro Guimaraes's avatar
Pedro Guimaraes
8 years ago
Pedro Guimaraes's avatar Pedro Guimaraes
Bugs:
  • The blue button to create a new entry at the top right is still there even if a channel’s number of maximum entries has been reached.
  • Grid fields: more often than not when I go to save an entry with a grid field, it’s adding a blank row at the top. Same is happening to empty grids.
Before and after hitting save:
https://willowlightstudio.com/images/tmp/1.png
https://willowlightstudio.com/images/tmp/2.png
  • Field manager: when viewing all fields, the search does nothing.
UI Issues:
  • I don’t think that Save & New is better than having Save and Save & Close. All my content editors save their entry as they work on it, with the current flow they’d have to reopen each entry to keep working on it.
  • When editing channel/fields, the container (that is blue) when you hover should be clickable and take you to edit.
Kevin Cupp's avatar
Kevin Cupp
8 years ago
Fixed, thanks!
Weird, can’t reproduce locally. Any JS errors? Looks like some JS may not be running.
The keyword search filter? I’m unable to reproduce this one.
Our bad, we meant for “Save” to reload the form, we’ll fix it.
James disagrees and says only the title link and edit pencil icon should take you to edit.
Thanks, Pedro!!
Pedro Guimaraes
8 years ago
There’s a JS error on the publish page when the entry does not have a fluid field, maybe that’s causing it? See it here:
https://willowlightstudio.com/images/tmp/3.png
Regarding the keyword search filter for the field listings page: /cp/fields – yeah it does nothing here, no JS error.
Kevin Cupp's avatar
Kevin Cupp
8 years ago
Ah missing comma, thanks!
Not sure what to tell you about the field listing.
Pedro Guimaraes
8 years ago
No worries. We’ll revisit once there’s a new DP. I’ll do a fresh install versus update to test…
