EXT constant
ronh's avatar
ronh
8 years ago
ronh's avatar ronh
Was the removal of the EXT constant intentional or an oversite?
Derek Jones's avatar
Derek Jones
8 years ago
Intentional, it’s not needed. May I ask what you were using it for?
ronh's avatar
ronh
8 years ago
ronh's avatar ronh
A third-party add had a require statement that used it (I’m not sure why they did it that way). Easy enough to fix.
Derek Jones
8 years ago
Gotcha, yep that should be safe to remove and replace with a full reference to the filename with the .php extension.
