"author_id":"Invalid Selection"
Developer Preview
TJ Draper's avatar
TJ Draper
8 years ago
TJ Draper's avatar TJ Draper
I’m getting an error when trying to register through Visitor on EE 3 and I’m completely stumped. I have reviewed all permissions related to member groups, channel form, etc. and I can’t resolve it. This form is using JSON and the return of submitting is:
{"success":0,"errors":[],"field_errors":{"author_id":"Invalid Selection"},"entry_id":null,"url_title":null,"channel_id":3}
Any help would be greatly appreciated as this needs to be resolved yesterday (as always, dev time to finish this upgrade has run out 😛 ).
Kevin Cupp's avatar
Kevin Cupp
8 years ago
I’m not sure what Visitor is or how it works, but this JSON looks like our Channel Form response. “Invalid Selection” typically comes from the option fieldtypes and happens when you try to select an option it doesn’t have. In this case, looks like the author_id dropdown.
Derek Jones's avatar
Derek Jones
8 years ago
I don’t have any experience using Visitor, either, and I’m assuming you’ve contacted DevDemon/Vector? I’d double check that the Channel prefs allow guest entries on Channel Form, and the default author assigned is in a member group that has permissions to create new entries in that channel.
TJ Draper's avatar
TJ Draper
8 years ago
allow guest entries
Ahhhhhhhhhh. That was not set correctly and apparently was not enforced on EE 2 or something in the context of Zoo Visitor adding a channel entry for the user. Or something.
