Nested Grid Tags Break?
anthony.pinskey's avatar
anthony.pinskey
9 years ago
anthony.pinskey's avatar anthony.pinskey
Is there a way to have nested grid fields within eachother from the same channel entry? I am trying to compare a multi-select list value to see if it relates to another field.
{exp:channel:entries channel="data"}
 {grid_field_a}
  {grid_field_b}
    {if grid_field_a:field_1 == grid_field_b:field_1}
     Match found
  {/grid_field_b}
 {/grid_field_a}
If you do the above without the conditional and just add the standard tag pairs to display values, it renders Grid Field B’s value, but the tags show as broken for Grid Field A
{grid_field_a}
 Grid Field B value renders here
{/grid_field_a}
Derek Jones's avatar
Derek Jones
9 years ago
Hi AnthonyP!
There is not a direct way to display one grid field’s columns inside another Grid field. Can you describe the contents that of these Grid fields hold, and what type of association there is in the multi-select content?
