Removal of safecracker module
guruhost's avatar
guruhost
9 years ago
guruhost's avatar guruhost
Hi all,
I’m trying to remove safecracker since it is included in the latest version of EE but without any luck. When I’m trying to uninstall it, I’m getting :
Unable to load the requested language file: language/english/safecracker_file_lang.php
Any idea?
Rob Allen's avatar
Rob Allen
9 years ago
Rob Allen's avatar Rob Allen
It sounds as if that file hasn’t been uploaded, or is in the wrong location.
You could try creating an empty file with the same name, upload it to that folder, then try uninstalling.
guruhost's avatar
guruhost
9 years ago
It doesn’t work, all I’m getting is :
An Error Was Encountered
Unable to locate the files needed to install this module
Even if I remove completely the folder from third_part plugins it is still showing as installed under modules.
How can I remove this manually from DB?
Jeremy S.'s avatar
Jeremy S.
9 years ago
Jeremy S.'s avatar Jeremy S.
Can you get the appropriate file from another install or backup files etc.?
guruhost's avatar
guruhost
9 years ago
Unfortunately not and I can’t find any version of it on Internet.
