Remove first image tag from {body}
MINDSCREEN's avatar
MINDSCREEN
9 years ago
MINDSCREEN's avatar MINDSCREEN
Hi
I want to remove only the first image tag from {body} using find and replace. I have installed {exp:low_replace} plugin, but I can’t able to do. Can anyone Please suggest how to do that OR suggest any other plugin for this?
Regards Debasish
Derek Jones's avatar
Derek Jones
9 years ago
Manipulating string content to find HTML tags isn’t ideal; can you describe why you are wanting to do this? That may give someone an idea for a better solution than what you’re trying.
MINDSCREEN's avatar
MINDSCREEN
9 years ago
I am using the main image as top image, and the same image with different dimensions are in body text too. I want to hide that without all articles.
Derek Jones
9 years ago
I would recommend adding a File field to your Channel, and possibly an Image Manipulation for the resized version. Then you won’t be using a plugin or PHP to try to perform regex on a string. The output would be as simple as:
Full size:
{news_image wrap="image"}
With a “Small” constraint defined:
{news_image:small wrap="image"}
And simply omit this variable from your tags when you don’t want it to appear.
