Switch and conditional
Finn's avatar
Finn
9 years ago
Finn's avatar Finn
The below doesn’t appear to work. The problem seems to be with the conditional. Splitting it into two separate conditionals yields the same results. Am I doing something wrong - is there perhaps a better way?
<!–Add a closing div tag every second entry, in order to close the row–> {switch='|</div>'}
<!–If the last row only has one entry, add a closing div tag so that the row is closed–> {if count == total_results AND “{switch='|</div>'}” != ‘</div>’} </div> {/if}
Finn's avatar
Finn
9 years ago
Finn's avatar Finn
Found the answer here:
https://willowlightstudio.com/news/2016/the-switch-conundrum-closing-tags-with-switch-statements-in-expressionengin
And for 3 columns this works:
{if total_results % 3 != 0}</div>{/if}
