Other authors' entries are showing on the Relationship drop-down field
October11's avatar
October11
9 years ago
October11's avatar October11
Hi all,
I have setup a specific-group members’ to only see the posts they have authored. On “Edit” these posts are showing fine. However, if I have a “Relationship” custom-field, everyone’s posts are showing for a particular Channel.
Is this a bug? Or there’s a workaround it?
Derek Jones's avatar
Derek Jones
9 years ago
What do you mean “to only see the posts they have authored”? Which member preference specifically? I can think of a number of use cases where authors would be allowed to select related content that they have no permissions to edit themselves.
October11's avatar
October11
9 years ago
Hey Derek,
You know how on “Members” settings you can setup for users to view/edit their posts only. In other words, if they go to a particular Channel, they will only be able to view entries they have created in that specific Channel.
I need the same thing happening with the Relationship drop-down / They can only view the entries they have authored in the Relationship drop-down.
The client has many members that need to manage their posts only / hence the request.
I’m not sure if this is a bug / or deliberate? — It could have been overwritten in the Channel Field, by setting the “Relationship” to show entries authored by the specific author only.
Does this make sense to you?
Derek Jones
9 years ago
The current behavior is intentional, as a content author may need to relate their content to others’ content that is curated by another department, etc. But I also understand your request. I’ll forward your feedback to the rest of the team.
TJ Draper's avatar
TJ Draper
9 years ago
TJ Draper's avatar TJ Draper
I’ve never actually needed to do this but having a setting on the field seems to make sense to show only entries authored by the current user.
