prefix="" parameter for tag pairs (i.e. namespacing)
Feature Requests
Mark Croxton's avatar
Mark Croxton
9 years ago
Mark Croxton's avatar Mark Croxton
For example:
{exp:my_tag prefix="my_prefix"}
  {!-- single variables --}
  {my_prefix:my_variable}
  {!-- variable pairs --}
  {my_prefix:my_variable_pair}
    {my_prefix:my_variable_pair:another_variable}
  {/my_prefix:my_variable_pair}
  {!-- not forgetting common iteration variables... --}
  {my_prefix:count}
  {my_prefix:absolute_results}
  {!-- ...and conditionals --}
  {if my_prefix:no_results}
  {if my_prefix:count > 3}
{/exp:my_tag}
I would suggest that the prefix parameter value - if it is set - is simply searched/replaced from ee()->TMPL->tagdata before the module/plugin tag itself is processed (so the module/plugin receives the tagdata with the prefix already removed). Therefore no change would be needed to any existing add-ons. It will “just work”. Possibly you could make it opt-in, via a setting for the add-on or a global config value.
This would solve significant parse order issues, and allow tags like channel:entries to be nested.
TJ Draper's avatar
TJ Draper
9 years ago
TJ Draper's avatar TJ Draper
I was sure I had made this feature request but I can’t find it. I must have just talked to the team about it at some point.
In any event, I actually do it manually on all my tags. For instance, Construct defaults to the {contruct:var}. The only difference is I use the parameter namespace. If the official terminology becomes prefix I’ll go with it but I like namespace.
I definitely would not say no to this becoming a default thing I didn’t have to do.
Sobral's avatar
Sobral
9 years ago
Sobral's avatar Sobral
This is one of the two things I most want to see on Template Class, after to allow arrays with arbitrary keys.
